Haltech E6X unit with flying lead harness. Includes Air temp sensor, coolant temp sensor and
GM 3 bar MAP sensor.
Includes 2 maps, one can be used with stock BP05 injectors and made ~ 99 whp and torque
The turbo map must be used with RX-7 injectors and you MUST have a compression ratio of
8.6:1 or you will need to pull timing as compression increases. Good to 12 psi on 91 gas and
made 240 whp and torque on the dyno.
The MAP sensor will compensate for changes in altitude so no worries sea level people.
Looking for 900 bucks obo.
(The tuning alone was more than this)
Will toss in injectors for 50 bucks:
[FS] Haltech E6X full standalone with dyno tuned maps
1994 MX-3 RS
Worklog: viewtopic.php?f=46&t=62251
B6 goodies for sale:
viewtopic.php?f=2&t=66333
2nd BP engine: http://www.clubprotege.com/forum/showthread.php?t=46695
Re: [FS] Haltech E6X full standalone with dyno tuned maps
and sold.
1994 MX-3 RS
