[GI] 1.8 gtx turbo part out
I have a turbo project mx-3 with a 1.8 bpt gtx motor, kia trans, motor has fresh head gaskets, arp head studs, new timing belt. i have the rear disc conversion done. considering parting out anything that anyone would be interested in. i haven't had any time to put any work into it and need to cut losses, just bought a new car. 8lb fidanza flywheel, stage 3 clutch, turbo header/manifold built for external wastegate 40 someodd mm, T3T4 turbonetics with shaft play needs a rebuild, custom 3" turbo back exhaust (no cat) but does incorporate a flex. can take pictures upon request.
- Evo_Spec
Re: [GI] 1.8 gtx turbo part out
it'll help if you post where are you located and how much you looking for =)
located in northeastern pa near the tristate border. pick up only on motor and trans and exh
1.8 gtx motor: arp head studs, fresh HG, intake mani, s3 clutch, and flywheel included 900obo
kia trans with half shaft, two axles, tranny mount. 400obo
front, rear, and pass. side filled motor mounts 60
will pull out rear end with disc brakes, master cyl, booster and front brake lines if the price is right and the demand is there.
turbonetics t3/t4 polished compressor, excessive shaft play 100 obo
3" turbo back exhaust 400 obo
i'll throw pictures on later tonight gotta go to work
manifold and t3/t4 turbo with shaft play.
2 shots of manifold intalled on vehicle.
wiring harness still good? and is there a tune on the ECU for the motor? might be interested in swapping this into my GS if its not gunna cost that much more then a DE swap
its a b6 harness rewired for the bpt i'm using the bp55 ecu (only issue is the CEL does not work). i have the harness tucked, would take a little time to pull it out.
