V6 aluminum Radiator
MX-3zoom
Post by MX-3zoom »
I am in the final process of starting up my swapped motor, but I've seen some members with after market all aliminum radiators (non-black), and so now i'm on the hunt for one! I've searched around online and most sites come up with 4cyl radiators. I dont know if they are the same as the V6(demension wise). Or if they are PnP, some are missing the coolant filler neck. Any help, or leads to one, I will be for ever thankful!!
___________________
Black '92 GS [Project De-t Started!] [The spoiled one] :twisted:
Green '95 1.6 [Daily][The jealous one...SOLD]
White '07 Mazda 3 GT [The pretty one]
[What can you say, I have a fetish for 3's]
mikeetown wrote: Do what you want to do dude cause in the end, your mx-3 is all about you.
tbondo
Re: V6 aluminum Radiator
Post by tbondo »
I'm pretty sure the 4 cylinder is different from the v6. If I remember correctly the top and bottom hoses are on opposite sides from one to the other. Size wise I believe they are the same but the connections are different.
V6 auto rad is diffferent frmo the V6 5-speed as well
davmac
Post by davmac »
Rockauto and autopartswarehouse have OEM replacements - some are all metal. These things are getting rare. I know that Probe and MX6 radiators can be made to work.
You'll have to adapt an all aluminum "racing" radiator to fit. Take dimensions off OEM, orientation of inlet and outlet. Search worklogs for other turbo projects.
Redline322
Post by Redline322 »
626 and mx6 v6 rads will work, you just need the T union to run the lower hose for the expansion tank and the longer lower bypass hose. You can get by with cutting the existing hose and inserting the union or get the proper hoses. If you cant find a donor car, the part numbers are:
KL56-15-189 and KL56-15-185 for 2 lower hoses
KL01-15-197 for union
KL01-15-184 for lower bypass hose
bbunkerc397
Post by bbunkerc397 »
1996 MX-3 KL-ZE with Eunos 800 IM, factory side skirts,. "Owner since 2001 my 14th year"
1992 929s 20B-REW Lowered, 17" chrome Millenia rims, custom black interior. "13th Owner 9th year"
2006 Chevy HHR LT "Bought Brand New - East Side Chevy" Sold to my Dad
stepchyld
Post by stepchyld »
4-cylinder radiators will fit, since chassis is the same, but radiator hoses are opposite those on the v6's. I know the MX6 v6 radiator is just a little bigger than the MX3 radiator and can fit, with a little work. I set my old mx6's radiator in to test the fitment, but decided to get an all-metal one from radiatorworld.com. I don't think they operate anymore though.
The atx radiator is different from the mtx radiator, but the atx radiator will work for a mtx car. You just have a little lower fluid capacity. This isn't a problem. I'm on my 5th year with that all-metal atx radiator (the only one they had for v6), no problems at all, and summers are rough here.
I don't think it was aluminum though, I can check tomorrow.
93 GS, ATX to MTX swap, chrome 16x7, upper strut bars, SRD LCA bushings.
Upcoming improvements: Tokico/Eibach struts/springs, energy suspension LCA bushings
94 RS MTX, Engine swap completed, ALIVE Again!
95 RS ATX, parts car/project X
DeadMaker
Post by DeadMaker »
Here is a v6 radiator for someone who is interesting..
http://www.ebay.com/itm/WINNER-RACING-5 ... 1c2c751a18
Black Mazda Mx3 Rs 1997 B6DE
kulluminati777
Post by kulluminati777 »
:2thumbsup: :2thumbsup: :2thumbsup: oh wow thats pricey but that would be perfect for my KLZE, i know what my Xmas present to myself is going to be
DeadMaker
Post by DeadMaker »
kulluminati777 wrote::2thumbsup: :2thumbsup: :2thumbsup: oh wow thats pricey but that would be perfect for my KLZE, i know what my Xmas present to myself is going to be
hahaha :lol:
Be patient only two months :lol:
Post by Josh »
This is all metal I thought they were aluminum but it looks like its is copper brass
https://shop.performanceradiator.com/in ... ct_id=8954
Bought from Radiators.com, delivered in like 1 day and the price was really good as well. 4 years later it's still going strong in my MX-6.
jaydog is back
Post by jaydog is back »
I have a custom 2 row all aluminum radiator in mine, complete with shroud and high flow fans. I payed around $250..I'll take a pic and let u guys see. When I see how much some of these other rads go for in other cars, it makes me think it's a rip-off. I can get one made for a v-6, same price.
wagZE
Post by wagZE »
I have put mx6/626/ probe gr rads in mx3 gs' with a little mod to the top part where the cap is. I've also put the auto rads in manual mx6s after just dumping out the auto trans fluid. You can find an aluminum rad in mx6s/ 626s/ pgts fairly often at the wrecker I know I do. Get those things for $20-30.
1 mx6 88 LX auto 2.2l 4cyl
2 mx3 93 gsze bought w/ mods
4 mx3 GS SOLD-
2 pgt primered 5 spd KL SOLD
