Choices for strut bump stops?
MrMazda92
Post by MrMazda92 »
I'm curious what others have done in this area, since there seems to be a lot of options.
My stock ones are too worn to go on with my Ground Controls, and the dust boot doesn't fit either. May as well replace both while I'm at it, but I'll need a much lower profile boot to clear the springs.
Any suggestions? What have you used?
Evo_Spec
Re: Choices for strut bump stops?
Post by Evo_Spec »
I used Energy Suspension one's on my setup but it wasn't actually my own idea because i bought my whole setup from someone off here a while ago but i really like them and would use them again if i were to get a new suspension setup for the GS
this isn't a great picture but you can see it on top of the yellow box there.
I might have a better picture but i need to go out right now so if i find it i'll post it up
Post by wytbishop »
I went to the picknpull and found a low km escort and took the struts apart and got all the rubber parts for $22.
MrMazda92
Post by MrMazda92 »
Thanks guys, I'm actually looking into this a little more in depth now, there's a hell of a lot more to it than I'd thought. Good stuff though, definitely worth the read!
Evo_Spec
Post by Evo_Spec »
you probably already know but i guess it might help to add that my struts were ZX2 struts
Post by wytbishop »
I am running ZX2 stock fronts and Tociko Blues in the back all on Eibach springs. If that helps.
mx3matt
Post by mx3matt »
MrMazda92 wrote:Thanks guys, I'm actually looking into this a little more in depth now, there's a hell of a lot more to it than I'd thought. Good stuff though, definitely worth the read!
i'm in the same boat, gc's and zx2's and been running about a year now no bumpstops or boots. the gc's have a smaller inner diameter that causes issues fitting normal stops(i tried).
been looking into energy suspension bumpstops but i'm gonna email ground control and see if they have any info.
MrMazda92
Post by MrMazda92 »
I tried that as well Matt, mine were also torn up to begin with though. :shrug:
This site: http://forum.miata.net/vb/showthread.php?t=415296 has only made it more confusing to me. :lol:
