[WTB] Coil Spark Cable
Posted: February 15th, 2012, 3:31 am
by WhiteFinish
Hi Guys,
I've just orderd a set of PRD Sparkplug wires but I'm also running an external coil. (Blaster 2)
Anybody knows where I can order a good spark cable for between the disti and coil ?
I prefer to have a cable that doesn't use a extra tower. Just plug into the distributor, and plug into the external coil.
Re: [WTB] Coil Spark Cable
Posted: February 15th, 2012, 5:28 pm
by 2fazed
I bought a MSD one from Autozone when I did mine. So some autoparts stores do have them.
Posted: February 16th, 2012, 2:47 am
by WhiteFinish
Is there a special kind of plug connection that I need to be looking for ?
Posted: February 16th, 2012, 5:28 am
by WhiteFinish
[QUOTE=Nd4SpdSe]I picked up a Blaster SS coil and it didn't come with a cable to go to my PRD cap. What's the part number for the MSD cable that will connect my coil to my cap? I was told to get the "MSD 84049 RED 8.5 Coil Wire Kit Socket Style" one, but the connectors on the ends of the cables don't work, it's too wide for the terminal but too narrow to go around the insulation.[/QUOTE]
I found this post of Nd4SpdSe,
So this cable didn't fit in the distributor and didn't fit into the coil ?
Posted: February 16th, 2012, 4:23 pm
by MrMazda92
I ran barefoot out to my '93 to check for you, on the off chance that there would be useful information on that wire. :( Sadly, all I can tell you is that it's an 8mm wire.
Edit: Mine does NOT look like that. The plugs on the end are not identical. One is noticeably larger than the other.
Posted: February 17th, 2012, 2:48 am
by WhiteFinish
Damn...
The coil cable I have now broke for the 3rd time in a row !!
Even though the guy made/repaired it right in front of me I need to try something else.
Who knows what kind of connectors we need than ?
Posted: February 17th, 2012, 3:56 pm
by 2fazed
MrMazda92 wrote:I ran barefoot out to my '93 to check for you, on the off chance that there would be useful information on that wire. :( Sadly, all I can tell you is that it's an 8mm wire.
On my RS, I had an all MSD setup that I bought from Autozone. On the GS above, I believe I bought a standard coil wire from Kragens(oreileys). You can take your cap and coil in and they can test fit a coil wire to it.
Posted: March 1st, 2012, 11:44 pm
by wagZE
viewtopic.php?f=15&t=77671&hilit=new+hei+idea
Try this out. Worked great for me.
