Hi Guys,
I've just orderd a set of PRD Sparkplug wires but I'm also running an external coil. (Blaster 2)
Anybody knows where I can order a good spark cable for between the disti and coil ?
I prefer to have a cable that doesn't use a extra tower. Just plug into the distributor, and plug into the external coil.
[WTB] Coil Spark Cable
- WhiteFinish
- 2fazed
Re: [WTB] Coil Spark Cable
I bought a MSD one from Autozone when I did mine. So some autoparts stores do have them.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
- WhiteFinish
Is there a special kind of plug connection that I need to be looking for ?
- WhiteFinish
[QUOTE=Nd4SpdSe]I picked up a Blaster SS coil and it didn't come with a cable to go to my PRD cap. What's the part number for the MSD cable that will connect my coil to my cap? I was told to get the "MSD 84049 RED 8.5 Coil Wire Kit Socket Style" one, but the connectors on the ends of the cables don't work, it's too wide for the terminal but too narrow to go around the insulation.[/QUOTE]
I found this post of Nd4SpdSe,
So this cable didn't fit in the distributor and didn't fit into the coil ?
- MrMazda92
I ran barefoot out to my '93 to check for you, on the off chance that there would be useful information on that wire.
Sadly, all I can tell you is that it's an 8mm wire.
Edit: Mine does NOT look like that. The plugs on the end are not identical. One is noticeably larger than the other.
- WhiteFinish
Damn...
The coil cable I have now broke for the 3rd time in a row !!
Even though the guy made/repaired it right in front of me I need to try something else.
Who knows what kind of connectors we need than ?
- 2fazed
MrMazda92 wrote:I ran barefoot out to my '93 to check for you, on the off chance that there would be useful information on that wire.Sadly, all I can tell you is that it's an 8mm wire.
On my RS, I had an all MSD setup that I bought from Autozone. On the GS above, I believe I bought a standard coil wire from Kragens(oreileys). You can take your cap and coil in and they can test fit a coil wire to it.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
1 mx6 88 LX auto 2.2l 4cyl
2 mx3 93 gsze bought w/ mods
4 mx3 GS SOLD-
2 pgt primered 5 spd KL SOLD
4 mx3 GS SOLD-
