FS: Lots of parts 95 mazda Mx3
Bumpysbro
Post by Bumpysbro »
PRICES LOWERED BY 50%!!!!! NEED THIS STUFF GONE! SHOOT ME OFFERS, NO LONGER HAVE SPACE FOR THIS STUFF SO GOING TO TRASH MOST OF IT IF I CANT SELL IT
hey guys been forever since i been on here, but i realized that i no longer have use for these parts that i stored over the years, mx3 is out of business body is crapped out and just sits there so its going to the be parted out. all prices are without shipping and are obdo since i just want to get rid of these parts. prices are OBO.I also have a rebuilt b6 dohc head/block with brand new crank if your interest but shipping would be a pain. Also if you need pics of any parts let me know you can reach me by email, or text me on my cell. thanks
Jon
Here are the full res images of the parts: http://photobucket.com/mx3parts
Email:jwdblueiddjman@gmail.com
Cell:(559) 737-7359
These parts were for a 95 RS with B6DE dohc motor
B&M Short Shifter: SOLD!!!
B6DE DOHC Rebuilt Cylinder head..Comes with cam gears, fuel rail, fuel wiring harness, fpr, stock fuel injectors
$200+shipping, i can do just the cylinder head for $165+shipping.
B6DE piston and rod combo.(Piston are STD size) ::::Bought these at http://www.importperformanceparts.com which are $40 each brand new piston/ring only:::
Pistons/wrist pins/locks/piston rings are brand new, rods are oem in working condition comes with used con rod bearings
$75+shipping
Reman Starter from autozone never used
$25+shipping
Bosch Spark Plug wires
$10+shipping
Stock B6DE Dohc Exhaust Manifold(CA manifold with Cat mounted under it)
$20+shipping
Two Sets of B6DE DOHC fuel rails with FPR mounted
$5+shipping each
Stock Fuel Injectors
$10+shipping
2 Clutch Throwout Bearing Release Lever
$5+shipping each
Speedo Gear
$5+shipping
TPS Brand New
$15+shipping
Pending Sale!!!!
Used MAF sensor never installed it so not sure about it being good
$5+shipping
Fuel Injector Harness
$10+shipping
1 B6DE DOHC Manual ECU
$15+shipping
Pending Sale!!!
Set of viton valve seals
$5+shipping
Brand new Topline Oil Pump
$35+shipping
Full Engine wiring harness uncut(with tps sensor/reverse light sensor)
$35+shipping
Pending Sale!!!!
Used B6DE Throttle body, comes with no tps or iacv valve or gasket
$15+shipping
Used EGR Valve for B6DE comes with bolts no gasket
$15+shipping
OEM Tailights(i have the light sockets with the wiring if you need it to)
$10+shipping each or 15+shipping if you want both
2 mazdaspeed seatbelt shoulder pads used condition paint is faded
$5+shipping for both
Pending Sale!!!
Climate Control with glow gauge overlay on it perfect working condition no cracks
$25+shipping
Driverside/passenger mirror(white)
$10+shipping each
Intake Tubing from Air box to TB for B6de engine(no rips or nothing)
$20+shipping
2 Used Oxygen sensors(not sure about condition)
$5+shipping
(Left manifold)Perfect Condition B6DE DOHC intake manifold!
comes with TB,TPS,IACV,EGR,all Vacuum routing/solenoids/caniter/VICS Valve
$75+shipping
(Right Manifold) Intake manifold with TB, IACV, VICS Valve and Vacuum Pipe
$35
All 4 Stock Engine/Transmission Mounts with brackets
$5+shipping each or $30 for whole set
2 B6de DOHC Valve covers
1s has never been painted, comes with valve cover gasket,pcv valve, and bolts
$15+shipping
2nd has been wirewheel'd, has no gasket and no bolts
$5+shipping
Last edited by Bumpysbro on October 18th, 2013, 9:32 pm, edited 28 times in total.
Evo_Spec
Re: FS: Lots of parts 95 mazda Mx3
Post by Evo_Spec »
could i get a shipping quote on the clutch to T2E4V1
not fully sure if i want it but depending on the quote, and if i do want it i won't have the money together for a little while so if it's still available then, then i'll probably buy it
im2bad4ya
Post by im2bad4ya »
Clutch line, 1 MAF sensor, 1 Speedo Gear, Reverse Switch - $35 incl. S&H to 07087??
-1992 MX-3 RS w/BP Swap Tropical Emerald Metallic "Lucky" 2005-2012 *REST IN PIECES*
Worklog: viewtopic.php?f=46&t=78176
-2003.5 MAZDASPEED Protege #882 Blazing Yellow Mica "Lemon Drop" 2012-2015 SOLD!
-2003 MAZDASPEED Protege #1186 Spicy Orange "Debbie" 2014-2015 SOLD!
-1980 Toyota Corolla Green 2014-present
-2002 Lexus IS 300 Solar Yellow 2015-present
Bumpysbro
Post by Bumpysbro »
Corksport Clutch line
1 MAF sensor
1 Speedo Gear
1 Reverse Switch
SOLD!!!
Disty and ECU
SOLD!!!!!!
Armrest
SOLD!!!!!!
1 Fuel rail and Injectors Pending Sale
Bumpysbro
Post by Bumpysbro »
adding parts until i get rid of everything, i also have a 95 rs dohc car for parts. so if you need body parts or interior stuff let me know. car is white in color, still got the suspension, wheels and tires, fenders, hood(not good shape) bumpers.
Bumpysbro
Post by Bumpysbro »
Hatch shocks(work great)
$10+shipping
Wiper Switch(Not sure if it fits other models most likely fits 94-95 rs models)
$15+shipping
Rear sway bar with bushings and brackets to mount it(no bolts)
$15+shipping
Brake Booster
$20+shipping
Brake Master Cylinder
15+shipping
if you want to combine the master cyl/booster $30+shipping :) :)
Clutch Slave cylinder to clutch master cylinder
$15+shipping
Clutch pedal with bracket
$10+shipping
Brake pedal with bracket(brake switch has crack on the plastic but still functions)
$10+shipping
Post by Josh »
PM SENT ABOUT ARMREST!......
NANO91
Post by NANO91 »
would speedo work for bp transmission.
92 RS- (2nd Gen) BP-Swap
viewtopic.php?f=46&t=76390
Bumpysbro
Post by Bumpysbro »
Josh wrote:PM SENT ABOUT ARMREST!......
replied to ur pm
Bumpysbro
Post by Bumpysbro »
NANO91 wrote:would speedo work for bp transmission.
not sure, if so i still have one left
NANO91
Post by NANO91 »
I don't wanna get one wrong again..
DeepBlueMX3
Post by DeepBlueMX3 »
_Hei Buddy.
What kind of material are made the HEAD gasket, metal or Graphite?
Can you give me a shipping cote to Brazil?
Thanks
MX-3 B6ZE Noble Green
SuperK
Post by SuperK »
I believe all headgaskets for the B6 is graphite, I've never met a steel B6 head gasket
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
My GS Worklog Thread
Bumpysbro
Post by Bumpysbro »
SuperK wrote:I believe all headgaskets for the B6 is graphite, I've never met a steel B6 head gasket
same here its graphite.
DeepBlueMX3
Thanks SuperK and Bumpysbro.
PM'ed about clutch...
