Clutch for boost
Edgar7654
Clutch for boost
Post by Edgar7654 »
ok i have successfully swapped a bp engine into my mx3 rs now im in the process of adding a turbo however i notice that my clutch slips with the new engine and with the turbo it should slip even more what clutch should i get once im turbo? are those ebay stage 2 clutches any good? i checked autozone and all they have is the stock oem ones
thank you for reading and god bless you!!!!!!
DeadMaker
Re: Clutch for boost
Post by DeadMaker »
have you swapped the transmission too?There is no way f series can handle the boost..
Black Mazda Mx3 Rs 1997 B6DE
Edgar7654 wrote:are those ebay stage 2 clutches any good?
eBay + Clutches = Bad
Evo_Spec
Post by Evo_Spec »
a lot of guys on here have SPEC clutches and i'm also going to be getting one when i do my clutch on my BP-T.
http://www.specclutch.com/
RS_OBD'oh_2
Post by RS_OBD'oh_2 »
I have a spec stage 2+ on my boosted RS F series that works very well. Mike has a spec on his BP+T G- series with LSD.
A clutch is not something that you will want to do too often. Have a TQ rating/goal and get a clutch rated above that goal. Keep in mind you get what you pay for and expect something in the $400+ range for a good setup.
