Need some help with remote starter info
RobMinhas
Post by RobMinhas »
Hey fellas,
I got my Prostart 2in1 remote starter set up from a shop a few days ago. They did a solid job and I'm pretty happy with it. However, I randomly found a wire caught in my alternator belt. It looks cleanly cut off on one side and the other side is just pulled apart like someone cut off the cable around the actual wire metal bit and then loosened, but not used it again. It looks like it was just garbage that they left in my engine bay. :shock: :x :cry: :freak: I'm gonna stop by and give them a serious piece of my mind tomorrow, however before I do that I want to check everywhere else in my engine bay they may have had wire go to to check for any other problem, just so I can get them for all of the mistakes and to see if they might've screwed something else up. I checked my engine bay andI didn't see anything else but with that being said, I do not know where to look. So can anyone point me to the right areas to look to see where they may have screwed it up? For reference its a 5speed 1.6L DOHC.
Thanks in advance.
Mi|<E
Re: Need some help with remote starter info
Post by Mi|<E »
Try to post a picture, probably a ground wire.
mikeinaus
Post by mikeinaus »
should be a wire near the ebrake, one by the clutch pedal one or 2 going to the ignition, probably one or 2 going for power (12v constant, and 12v with ignition) one going to a latch pin in the engine bay for the hood, one or 2 going to a shock sensor, another 1 or 2 going to a loud speaker, some to doors, possibly windows and hatch release. it depends on the features but they are fairly complex and there is more then likely a tun of wires going all over the place. shoudlnt be too hard to tell if they did quality work by tracking down a few wires and seeing how they connected everything. ie butt connectors or actual solder/heat shrink.
