14" wheel on mx3 GS?
valk1317
Post by valk1317 »
stock is 16"i think. one of the tires has a slow leak or broken seal so im looking at getting a set of used volkswagon wheels with good tires for really cheap. will 14" fit the calipers? 92gs
Re: 14" wheel on mx3 GS?
Well I suppose it depends on the type of rim but I was running some 5 spoke 14" american racing wheels without a problem on my 92 GS. I believe the stock 14" RS butterfly wheels will work as well.
Sleeper6
Post by Sleeper6 »
They should the same calipers are on RS and they come factory with 14 honeycombs.
RobMinhas
Post by RobMinhas »
I had 14 inch steelies on for a bit and they didn't rub on the callipers, this was on my RS, although they were on a GS before and they were fine. Worst come to worse, just throw them on then and there and see if they're good.
Ryan
Post by Ryan »
What you need to know is the rim contour. Ours is "JJ". It is a common one, civics from the 90's and 00's, most econobox cars, really. Another concern is offset. We are +45mm or "high offset"
If will be stamped on the rims somewhere.
mikeinaus
Post by mikeinaus »
im running some 14" vw rims on my car for the winter. no problems so far...
Dragon1212
Post by Dragon1212 »
If the 14's you run are on par with stock rs rims you will be fine
Worklog for the Blue One
Worklog for the KLZE
First Car, And My baby... $550 To buy and repair from Write-off... The radio and amp that was in it was worth more than that!!!.
Hunting For a Supra MKIV, but I'll never get one. Still Hunting.
jamestakay
Post by jamestakay »
Just trying to figure out how you got 16" mx3 rims stock? Weren't they all 14s or 15s? And if you do get the 14s you'll just have to get bigger tires to match up for the speed.
Evo_Spec
Post by Evo_Spec »
jamestakay wrote:Just trying to figure out how you got 16" mx3 rims stock? Weren't they all 14s or 15s? And if you do get the 14s you'll just have to get bigger tires to match up for the speed.
i was surprised no one mentioned this error as well, yes all the stock rims were either 14" or 15"
jamestakay
Lol, I was thinking, I never had the special edition mx3 but I don't think they were 16s for the 5 star rims. lol. Oh well, some of us just look too deeply at times but it's all good.
