Alright guys, I finally acquired some H4 capable housings, and am already springing for 100w bulbs(and all this entails).
My question, is how my fellow North Americans have wired their non A-Spec lights in? Custom one-off job? Similar pigtail from another model? I'm all about clean, so I'd prefer to avoid loose wiring in my bay.
Thanks!
J/E-Spec headlight install question
- MrMazda92
- solo_ryder
Re: J/E-Spec headlight install question
You need to get a H4 pigtail harness from a car parts store and rewire the 3 original wires to the 3 new wires. The High and Low are usually swapped around so look at some diagrams online to see which pinouts do what. If you have the oem harness from the headlights then you do the same thing... Hack the OEM wires before the OEM plug and then wire em straight to the new wires. I used butt connectors with electrical tape, but soldering is proly a good idea.
Also, HID kits work well in the EDM and JDM housings with adjustment, 100watters can sometimes burn out old wires, but you will proly be ok. HIDs usually run 35-55w
- MrMazda92
Thanks for the reply solo.
Do you happen to know a source for the rubber boot that surrounds the pigtail by any chance? I'd like to keep it as waterproof as it should be.
It will all be soldered into place, and I'll be using Sleeper6's writeup for the wiring upgrade.
Finally I'll be able to see at night.
- solo_ryder
Yea when i upgraded to jspecs I was really happy, even with 70watters that I had in there, cutoff and distribution where alot better.
Im not sure what rubber you are talking about.. The headlights have caps on the back of the housings.. not sure where you can get some? Maybe off another car
- jeffs93toy
you could always use heat shrink tubing.
My feedback viewtopic.php?f=37&t=78944
My worklog viewtopic.php?f=46&t=78228
My want to buy viewtopic.php?f=48&t=79033
- MrMazda92
I assumed it was rubber, as my other vehicles with H4 bulbs have the harness shrouded and protected by a rubber boot. It could be plastic, but honestly I would be surprised.
There are caps, but I don't see how you would attach the harness around them. Actually, now that I take a closer look it makes more sense to me.
Upon looking at the housing after fresh rest, I noticed the notched sections. I can only assume that you feed the pigtail wiring in through these, and use the cap to cover the pigtail itself. It makes sense, I am surprised I didn't see it sooner.
- solo_ryder
Yea the wire goes around the circle there and the cap goes overtop
- MrMazda92
Thanks! I can't believe I didn't notice that before... Geeze.
