suspention work
- stangant
suspention work
Well seeing as my car is a 93 and I can tell that the shocks and struts absolutely need replaced. What is the recommended replacement? I will not be lowering the car at all as it is my around town car and my mustang is my monster. haha OH and it is a GS btw. I'm guessing that probably matters with that big ol v6 stuffed in the front.
- MrMazda92
Re: suspention work
OE quality replacements will do you just fine. I'm running them, and couldn't be happier. Granted, that's a daily driver that doesn't see track use... Yet.
I'm anti-lowering for daily drivers, so I respect that you're avoiding that.
Re: suspention work
KYB makes a very good shock for our cars. If your springs are bagged too you can stil get them from the factory I think. Any other replacement spring is going to be significantly stiffer than stock.
- marcdh
Re: suspention work
so good they are OEMwytbishop wrote:KYB makes a very good shock for our cars.
View Worklog
![Image](http://marcharrington.co.uk/banner2013.png)
View Worklog
- stangant
Re: suspention work
ok thanks
Re: suspention work
I still like my H&Rs and OE shocks on my daily. Keep in mind if your running on 18yr old suspensioned its already lowered from age. I didnt even notice I height change when I swapped springs as worn as my suspension was. A worthwhile trade for the upgrade, heck even the alignment was on with out using camber bolts too!
I modify my ride so I can drive around the stupid people ![Very Happy :D](./images/smilies/icon_biggrin.gif)
- stangant
Re: suspention work
I just went to the part store and they will be 80$ a piece... That is ridiculous. I am looking online for a good website now..
Re: suspention work
If you are in the states www.rockauto.com has KYB's for I think 45 each. Shipping within
the states is pretty reasonable.
![Image](http://i147.photobucket.com/albums/r298/mikefoo/bpt-small.jpg)
1994 MX-3 RS
Worklog: viewtopic.php?f=46&t=62251
B6 goodies for sale:
viewtopic.php?f=2&t=66333
2nd BP engine: http://www.clubprotege.com/forum/showthread.php?t=46695
- Josh
Re: suspention work
cheapest place I know of is Shox.com you will have to look under escort. 80 each is kind of steep for OE replacements. one thing that might help with your springs would be to swap the driver side spring with passenger side spring. usually the driver side will get a bit more sag over the years.
- stangant
Re: suspention work
thanks guys, I have a new issue..
I am hearing a "bump/rattle" something not doing what it should from the front driver side "on the left" so ima pop the wheel off and see whats up.
- mazda915
Re: suspention work
dont go cheap man . kyb are ok .. i recomend ksport . a lil pricy but well worth the feel and the lowness
1992 gs k8ze . 4 inch tip 2.5 cat , cold air intake ,corksport front and rear stut bars home made upper pillar bar , prosport gauges,megan racing 4 pts harnest, 10,000 K HID's , ksport suspension ,
- Evo_Spec
Re: suspention work
mazda915 wrote:dont go cheap man . kyb are ok .. i recomend ksport . a lil pricy but well worth the feel and the lowness
stangant wrote:I will not be lowering the car at all as it is my around town car and my mustang is my monster.
Re: suspention work
...and who the hell has money for K-Sports?
- Josh
Re: suspention work
This is some kind of oxymoron "dont go cheap man" ... "Ksport"... Really ... Really? for one he said OE replacement and for two look above, 3. if 80 each for OE replacements was too much then obviously Ksports are not on his list. BTW Ksports... They are cheap...
