Page 1 of 2
rim size
Posted: November 26th, 2011, 4:08 am
by jeffs93toy
Hey does any one know what the bolt pattern is of a 97 mazda 626 (5 stud)?
Also what size rims can we put on our mx3, 18x8 , 17x7, ect. Thanks in advance.
Re: rim size
Posted: December 15th, 2011, 3:45 pm
by youdirtyfox
Im running 15x8 ET15 with 195/50/15 Tires and rolled arches and its very flush so that gives you an idea of how wide you can go.
I do not understand your fascination with 17's or 18's over here though!
Re: rim size
Posted: December 15th, 2011, 4:13 pm
by Josh
I think the MX's wheel wells are so big they are meant for 17 or 18 inch wheels. I have 17x7 with like a +42mm they fit great could be more flush though, thats why i got spacers. I think with the proper offset you could get 17x8 or 9" under it. 18's are HUGE and with the proper rubberband size tires it makes the ride height look like a truck. I like 18's but the car is so small it looks a bit off in most applications I have seen.
But to answer your question the 626 5 lug bolt pattern is 5 x 114.3 and you CAN run 17 and 18 inch wheels
Re: rim size
Posted: December 15th, 2011, 4:18 pm
by Nd4SpdSe
What I want to know is what is your plans to put 5-bolt rims on a 4-bolt car?
Re: rim size
Posted: December 15th, 2011, 5:06 pm
by youdirtyfox
Josh wrote:I think the MX's wheel wells are so big they are meant for 17 or 18 inch wheels. I have 17x7 with like a +42mm they fit great could be more flush though, thats why i got spacers. I think with the proper offset you could get 17x8 or 9" under it. 18's are HUGE and with the proper rubberband size tires it makes the ride height look like a truck. I like 18's but the car is so small it looks a bit off in most applications I have seen.
Yeah they are massiiive agreed, but its only a small car :P
and with 17's and a decent low ride height you will end up with some nasty reverse rake
like this:
Re: rim size
Posted: December 16th, 2011, 11:18 am
by Josh
He probably dates fat chicks...
I never never had that issue with my RS running Eibachs. But that's what GC's or coilovers are for :)
Re: rim size
Posted: December 16th, 2011, 12:00 pm
by Ryan
Excuse my ignorance... what is reverse rake?
Re: rim size
Posted: December 16th, 2011, 12:10 pm
by wytbishop
reverse rake would be negative castor I guess.
I'm running 17x7 et 42 and it's very very close to the strut body on the inside. But it does look really good. Be warned though, if you put a large open design wheel like a 5 spoke with thin spokes it will really highlight how small the stock brakes are.
looks kinda goofy.
Re: rim size
Posted: December 16th, 2011, 2:14 pm
by Josh
:lol:
The rake is the angle in which the car is sitting relative to the height from front to rear. A front rake would have the front of the car lower than the rear, but in this case it is revered with the rear end lower than the front.. Which if you had your car corner weighted and balanced they would do this to get it as close as they can to a proper 50/50. Really has absolutely nothing to do with the size rims if you have the proper dia tires to go along with them. The rs is 205/40/17's and the GS is 215/40/17's
Re: rim size
Posted: December 16th, 2011, 2:36 pm
by Ryan
Thanks, I never know what to call that :D
GF's civic had massive reverse rake when we lowered it, so we put the stock springs back in the rear and look way better. I love a bit of front rake.... makes it look super aggressive.
Re: rim size
Posted: December 16th, 2011, 5:16 pm
by RS_OBD'oh_2
Josh wrote::lol:
I have 215/40/17's on my RS. No issues
Re: rim size
Posted: December 16th, 2011, 5:30 pm
by Josh
RS_OBD'oh_2 wrote:
Josh wrote::lol:
yeah I run 215's as well. It is supposed to throw the spedo off by 2mph
Re: rim size
Posted: December 16th, 2011, 5:41 pm
by RS_OBD'oh_2
ahh. Good to know, thank you
Re: rim size
Posted: December 16th, 2011, 11:18 pm
by MrMazda92
Josh wrote:He probably dates fat chicks...
The whale-tail caused the rake. :lol:
Re: rim size
Posted: December 17th, 2011, 10:11 am
by youdirtyfox
Ive seen plenty of reverse raked mx3's on here with 17's Im afraid , even mooneggs has a touch going on and He has coilovers! even though His car looks parralel to the ground along the sill the rear wheel to arch gap is smaller than the front thus giving the look of reverse rake.
Its funny you go alot of miata forums and they will laugh you out the park for wanting to put 17's on a miata, most of them wanna run 14's
Its just too much wheel for me for a small car and I know im banging my head against a brick wall here so I'll shut up now :P
