94 gs stock spoiler rattles how to fix?
evaunit360
Post by evaunit360 »
The left side of my spoiler rattles and I can hear it when I drive. I the bolts seem tight.
mikeinaus
Re: 94 gs stock spoiler rattles how to fix?
Post by mikeinaus »
3m industrial 2 sided tape might work. id remove the spoler then clean the car and bottom of the spoiler. attach the tape to the bottom of the spoiler and then reattach to the car.
evaunit360
Yea, I was having trouble figuring out how to properly remove all that plastic trim that surrounds the access to all of the spoiler bolts. I gave up and was wondering how to pop off all that plastic.
mikeinaus
Post by mikeinaus »
take out the plastic hook thingys that the hatch divider rope attaches too, then pop it out as best you can. it uses metal clips that can be tough to get out. it will take some force but try not to break your panel.
Evo_Spec
Post by Evo_Spec »
evaunit360
Thanks!
MrMazda92
Post by MrMazda92 »
Be careful removing that trim... For some reason I still can not get my 3rd brake light cover back on completely. I've removed and replaced it repeatedly, and honestly just gave up. :shrug:
Return to “Appearance”
