Daninski wrote:Money well spent would be money spent on an LSD.
Definitely. They're expensive, but they're worth every penny.
Daninski wrote: Never understood the battery in the trunk deal when we already have a problem with front wheel spin. Anyway, CF hatch and lexan is a nice cosmetic upgrade but as far as any weight loss vs performance gain I'm skeptical. I will say, that damn hatch is heavy.
It all depends on the application. If you're gonna use the car for straight line racing, moving the battery to the trunk is one of the dumbest things you can do.
But if you are, for example, gonna autocross, or road race, wheel spin is nowhere as important as weight balance. Having the wheels glued to the pavement means very little, if you have to slow down on every curve, because your car won't turn.
The weight savings vs performance relation has been well documented, and it's very real. But you have to be smart about
where you save weight. On an mx-3, and being that I am, first and foremost, a road racer, I'd pay much more attention to the front end, and leave the rear end pretty much stock.
