5 speed swap speed sensor
Posted: September 10th, 2011, 7:36 pm
hey so i finally got the clutch pedal in the car and all bolted in. i was looking at the atx and mtx tranny side by side and noticed that the atx that came out used a digital speed sensor while the mtx uses a cable speed sensor. both trannys are from 94s, mtx is from a protege that had NO TACHOMETER, only a speedometer which is odd because its a 5 speed.
both speed sensors are the same size and very similar in appearence and both fit in either or trannys. so the question is would i be able to use the speed sensor from the atx in the mtx? i'd just plug it into the atx engine harness does that make sense? thanks
