[WTB] Rad cap attachment
Weird. My installed KLZE has a plastic housing beneath the rad cap, it has a slight crack in it. I bought an entire disassembled KLZE, and thought I could just exchange it... nope. That one has an all aluminum, one piece neck.
Anyone got the little plastic piece, it's held down by two 8mm bolts.
92 Mx3 GS KLZE 5 speed
97 Dodge Dakota - Boyd rims, custom built 5.9 360, custom tranny with kevlar guts and shift kit. Too many upgrades to list.
92 Mazda 323 - winter beater
mx3 by Leadfoot Lesley, on Flickr
- Ryan
Re: [WTB] Rad cap attachment
I have one, in aluminum.
It was on my 92 K8. Or was it a 96 K8. I forget.
Address? I'll do shipping rounded up to the nearest 5. ($10 or 15 I bet)
Thanks, I have the aluminum one. It would be a pain in the butt to install the entire all-aluminum neck. The one that's in the car has a plastic moulded housing on top of the neck, held down by two 8mm bolts. The cap screws onto this.
- Ryan
yes, I have that little piece in aluminum, not the whole neck
Really? Wow that's great, then yes I will take it!
I'm in Ontario, K9J 2A5.
I can Paypal you...
I can Paypal you...
- Ryan
aaaannndd I'm a jerk.
Its actually installed on the motor I just finished putting together. It had the two coolant sensor taps on it that I need...
Sorry
If I head to the JY tomorrow, I'll keep you in mind.
Sorry
Those plastic ones suck. Go to the picnpull and check other Mazda's I'm sure there's one there to fit your car. If I could find mine you could have it cheap but I don't have time to look till Sat. Where in Ontario do you live?
I'm in Peterborough. Checked a couple of yards today, but no luck.
Ha, I was just there the other day doing an HVAC job. I've seen a couple of MX-3s there. One nice looking red one. I'll check this weekend. In the mean time clean yours and scrape the crack with a knive to creat a little V in the crack, sand the area and apply some 5min epoxy. Should hold for the short term. Cheers
Thanks, I will try that.
Mine probably wasn't one of the nice ones you saw, although it is red. It looks like it was painted with a mop.
Idiot, we all know your suppose to use a Swiffer.Lesley wrote:Thanks, I will try that.
