Adjustable FPR
mazdaspeed23
Adjustable FPR
Post by mazdaspeed23 »
does anyone know where i can buy an adjustable FPR? and door sills. stainless steel or something flashy
Own
1994 MX-3 GS swapped ZE
1994 MX-3 GS Swapped ZE (Gone)
1996 Dodge Dakota Sport v8 Magnum
2007 Ford Fusion SE
WORK LOG: http://mx-3.com/phpBB3/viewtopic.php?f=46&t=81232
My MX-3 is nothing without me, and i am nothing without my MX-3
Re: Adjustable FPR
These AFPR comes in a choice of colours and I like the gauge being integral to the unit. http://www.cosmoracing.com/productinfo. ... 9&pid=1040
marcdh
Re: Adjustable FPR
Post by marcdh »
The cosmo ones aren't bad. I thought mine had failed, turned out it was a duff walbro fuel pump. Doesn't seem quite as stable as the aeromotive, but did the job for my ZE.
View Worklog
Re: Adjustable FPR
What part number is your Aeromotive pump?
Mr.mx-3
Re: Adjustable FPR
Post by Mr.mx-3 »
Daninski wrote:These AFPR comes in a choice of colours and I like the gauge being integral to the unit. http://www.cosmoracing.com/productinfo. ... 9&pid=1040
I see they only list for the K8 I'm interested in putting one on my ZE do they have those as well or they the same for both?
GS-ZE,fidanza fly/ 6 puck ceramic clutch,pacesetter headers/exhaust, AWR 88duro motormounts, P.R.M jetstream CAI,KYB GR-2 struts, KL31 ECU,JE-50VAF,110A Mellenia alt. S.S Corksport Clutch line.
Jutzi420
Re: Adjustable FPR
Post by Jutzi420 »
Had a cosmo. I could adjust it, but it wouldn't raise pressure under acceleration. I pitched it. Then I got an aeromotive, more money but the thing works like a finely tuned clock. Being able to dial the pressure back (and testing under hot-rod) is the only way I've been passing e-tests with my ZE
Re: Adjustable FPR
Ok so where's the best place to buy the Aeromotive? Additionally, you should only need Hot Rod status to pass a E test with the ZE. What pressure did you dial the AFRP back to?
