4 CYL Cold Air Intake Questions???
Posted: July 16th, 2011, 3:32 pm
So hers the skinny...i have a make shift cold air intake on my 4CYL MX-3. what I mean by that is, I have the stock plastic intake tube from the TB to the MAS, After the MAS I have a piece of aluminum tubing which sends the intake behind the driverside headlight into that little pocket where the old air intake box used to be.
Becuase we have 2 vaccume hoses running off the air intake just before the TB, I cant seem to find a ebay cold air intake that has the same "bungs" for the vaccume lines. I know the 1st vaccume line (the smaller of the two) goes to the PVC inlet on the valve cover. The second (bigger vaccume line) I have no clue what it is for or where it goes?
My Questions:
(1) does anyone know what that Bigger vaccume line is?
(2) does anyone know how I can get a hold of a intake tube with the correct "bungs" for our vaccume lines? (p.s. I relocated my battery to the trunk so fitment issues are a non-factor...lots of room)
Thanks always for the advice
Chris
My Questions:
Chris
