(Pic request) MX-3 with wheel spacers!
johnmx3ze
Post by johnmx3ze »
im looking for a picture of an mx-3 with wheel spacers...
i also need to know what size in mm and brand of the spacers...
thanks
john
BornSticky
Re: (Pic request) MX-3 with wheel spacers!
Post by BornSticky »
bump! :welder:
#5389 to join MX-3.com
Hoodzy
Post by Hoodzy »
The measurements provided are going to give you that exact extra space no??
2mm will be 2 extra mm!??
1995 Creek Mica Blue GS
johnmx3ze
Post by johnmx3ze »
no one has an mx3 with spacers?
Inodoro Pereyra
Post by Inodoro Pereyra »
johnmx3ze wrote:no one has an mx3 with spacers?
Using wheel spacers modifies your scrub radius (unless you're using them to compensate for a wheel with a different offset than stock).
A scrub radius difference of just a few millimeters would have a deep influence on the car's handling and road feel. I doubt many people would use them, for anything other than show cars. :shrug:
Diogenes of Sinope.
tehbrookzorz
Post by tehbrookzorz »
I ran spacers because my free tires were too big and contacted the spring-mount on the struts. I think the spacers were 1/4".
He's right, avoid spacers when able.
Cody
stereoking15 is running either 5 or 10 mm spacers (H&R) so that he can fit 235/40/17 with stock struts.
Check posts in this thread after 4/7/09 for pics of his blue/white mx-3: http://www.mx-3.com/phpBB3/viewtopic.php?f=21&t=69477
WhiteFinish
Post by WhiteFinish »
Try to take a look at the German Mx3 forum.
In general Germans like spacers.
Just another Mx3 freak :)
Feedback topic: Click
Worklog click
Post by Josh »
I have 15mm in the rear and 5mm in the front no pics yet though. Only reason is to push my wheels to the outside of the wells. Hella flush look... lol
why do you need pic so bad? what wheels are you running wanting to run offsets? you don't need spacers if you get the correct offsets
johnmx3ze
Post by johnmx3ze »
i want the hella flush look too..
Polonius
Post by Polonius »
I have 4x114.3 bolt pattern wheels from my previous car I wanted to continue using, as well as wanting the flush look. I bought spacer/adapters that are 1 inch wide for all four tires. Personally, for my commuting/zipping around 50 kph curvy roads, I found the handling, ride smoothness, and body roll were all very improved. It felt a lot more poised to me. Here's some pics! (I just bought them off ebay... :P )
1993 MX-3
B6 SOHC
170,000 k
Manual tranny
_-Night-Shade-_
Post by _-Night-Shade-_ »
Polonius wrote:I have 4x114.3 bolt pattern wheels from my previous car I wanted to continue using, as well as wanting the flush look. I bought spacer/adapters that are 1 inch wide for all four tires. Personally, for my commuting/zipping around 50 kph curvy roads, I found the handling, ride smoothness, and body roll were all very improved. It felt a lot more poised to me.
That's illusory correlation. Spacing the wheels out further from the suspension actually reduces the effective spring rate because more force is exerted on the suspension (same principle as to why it's easier to turn a longer wrench). So you actually have more body roll now. And more wear on the wheel bearings. It's probably not too drastic of an effect but it's there. I imagined 1" would have pushed them out further than that. Do you know what the offset for those rims are? Also would be curious to see what that looks like on a lowered MX-3.
fillpereira
Post by fillpereira »
Uk sam's has pics on his work log
viewtopic.php?f=46&t=74195&start=75
hotsiit
Post by hotsiit »
Josh wrote:I have 15mm in the rear and 5mm in the front no pics yet though. Only reason is to push my wheels to the outside of the wells. Hella flush look... lol
Wondering what offset you are at with the 15mm spacers on? I am thinking of using 15mm spacers too, effectively pushing my offset to +27. (I think i read somewhere that a +25 offset on an mx-3 is pretty much flush with the fenders?)
1993 Mazda MX-3 RS-Turbo
1993 Mazda RX-7 touring
1983 Mazda RX-7 GSL
1987 Jeep Comanche
tehbrookzorz
Wait, you can figure this stuff out with a measuring tape and some sketches..
Cody
