Millenia S rod
Djdaveflow1
Millenia S rod
Post by Djdaveflow1 »
Does it fit on my Klde? with Wiseco 21mm piston?
MrMazda92
Re: Millenia S rod
Post by MrMazda92 »
It'd fit, but we'd need more info than that to compute CR for you(assuming you don't know it already...)
It IS one of the more common options for low-mid boost builds.
