i got a problem with my engine
xXsalvador
Post by xXsalvador »
:welder: i just fixed my mx3's engine but it still turns off automaticly when i stop. But this just happens every once a while i dont know what the problem is. so can some one please explain?
xXsalvadorXx Mazda MX-3 94
RS_OBD'oh_2
Re: i got a problem with my engine
Post by RS_OBD'oh_2 »
this could be many options. What was wrong with your engine? What did you work on/touch. Could be as simple as a VAC leak.
Does it stall or does your key actually turn into the off position? <- if it does that I would say get a priest.
What is the year,model,tranny info?
Funny, mine was stalling when I stopped too if I took my foot off the gas abruptly. Two weeks after it started my fuel pump went. Replaced the pump and no more stalling.
xXsalvador
94 manual... I just changed the fuel pump,oil change and did a tune up. Plus i add a cone style filter but it worked a little bit better than it use too i still dnt know the problem.
RS_OBD'oh_2
where did you place the filter? Did you remove any hoses when working on the intake? If there is a leak you will stall like a mofo
xXsalvador
Na i put every thing back in its place. But this one day it was weird i got home and i let go of the gas pedal and left it in neutral and the car accelarated its self and it stayed like that for about 3 to 5 sec and it stoped and went back to normal it was pretty weird. But im still guna go ahead and check if thers a leak.
DeepBlueMX3
Post by DeepBlueMX3 »
Probably you need a TBI cleaner and to adjust it, there is a thread here in the forum, just use search tool.
It can be a vacumm leak as RS_OBS'oh_2 sad, or any closed hose after the air filter installed.If you retired the air filter intake box the thin side vac hose must be openned or the engine will die when you stop the car, or when you press the clutch.
MX-3 B6ZE Noble Green
DeadMaker
Post by DeadMaker »
Really what does this hose do?
Black Mazda Mx3 Rs 1997 B6DE
DeepBlueMX3
It's an extra air source to the tbi when you keep off acelerator, or when you turn on the air conditioner.
Scariestwalnut
Post by Scariestwalnut »
Could also be a MAF/VAF problem. When i bought my car, it was doing the same thing and it was because the maf wasnt plugged in well. it was sticking out a bit.
Current Worklog ---> http://mx-3.com/phpBB3/viewtopic.php?f= ... 80#p581580
1996 1.6 automatic Mx-3 -----> Sold
1993 2.5 KL-DE Manual Mx-3--> In parts in my parents Shed xD
1994 1.8 K801 Manual Mx-3 ---> Daily, dropped, racing stearingwheel, KL-DE to come
1997 2.5 KL-ZE manual Mx-3 --> Piston #6 = BLOWN TO PIECES
