Brake Master Cylinder slimming?
- cWs306
hey, does anyone have a guide on how to shorten the brake master cylinder? i wanna use the straight neck.. any info helps! thanks!
- Ryan
Re: Brake Master Cylinder slimming?
it is on here somewhere... not sure why you can't be doing this search.
http://www.mx-3.com/phpBB3/viewtopic.ph ... ke+booster
You do it a few ways, the best is to convert to the MX6 break cylinder. Did you stiffen your motor mounts? Without the mod and if you still have stock mounts your engine (intake) could hit the master cylinder.
- cWs306
i did ryan, i couldnt find anything.. i only post stuff if i cant find it with the search.. lol and yah im not very good with it, i can never find anything that answers me question. and yes i stiffened them, used the flexane 94 stuff.. should i drill holes in them still if im going with a straight neck? or keep them stiff as possible? lol.
I know 1sickmx3/6 modified his rear mount on his, I think he raised it to make it clear better, but definitely keep it stiff
