manual to power window swap....
Awhile ago i was in a wreck, destroyed my passenger door, bought a parts car (was cheaper than getting an actual door) but... its got manual everything and a tan interior (yuck). i went to swap out the manual and electric motors in the window yesterday but the motor wont work. There are three more plugs on the electric harness than on the manual, all which will fit into the plug for the motor. i tried all of them and nothing... but my power mirror works..... is there a difference between the 92 and 93 that wont allow the swap? or maybe the switch is shot?
- 2fazed
Re: manual to power window swap....
The mirrors are on a different fuse and switch. There's a button on the master switch that turns the passengers switch on and off. You can test the plugs on the harness with a light tester. If it's got power, and the switch doesn't make the window go up or down, my money is on the window motor.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
