What tires u rollin'on?
johnmx3ze
Post by johnmx3ze »
i wanna get new tires for the mx3 (205/40/17) but i dont know which tires is the best quality/price wise...
please help me chooses good tires for a 300whp + car... :D
let me know what your rollin' on!
i have lexani p.o.s tires right now and there almost bald!
thanks guys!
Mi|<E
Re: What tires u rollin'on?
Post by Mi|<E »
Yokohama Parada or S. Drives
Note these are for summer only, no ice/snow ever
johnmx3ze
Post by johnmx3ze »
my mx3 stays in the garage for winter! :P
anyways ive been looking at the Falken AZENIS RT-615K they look awsome!
does anyone have thoses?
johnmx3ze wrote: anyways ive been looking at the Falken AZENIS RT-615K they look awsome!
Actually those tires are on the short list for the 8, she needs new tires when she gets on the road.
Mx-3 had Kumho MX's up front, and Escta 712's in the rear. Also in 205/40/17, but next batch I was looking into getting something bigger/wider for the front (see: Pontialc GrandPrix GXP)
solo_ryder
Post by solo_ryder »
205 40? Get 215 40. Looks better and is abit wider
johnmx3ze
Post by johnmx3ze »
215 would make them wider? do you think it would look better then 205?
solo_ryder
Yea, 205 has a smaller sidewall too, 215 is abit more beefy and you can still get lots of tires in that size. That is all I ran on my 17s and I liked them better then 205 40 which is too small anyways. 215 40 is closer to OEM circumference
Ryan
Post by Ryan »
I'm a little worried that you have to ask if 215 is wider than 205.
solo_ryder
lulz, they are just numbers bro, the higher the number the higher the priceeeee
johnmx3ze
Post by johnmx3ze »
i asked if it would look better then 205...
You can buy my Yokohama 205/40 17 for about $250. They have about 5k on them. See them here http://www.mx-3.com/phpBB3/viewtopic.php?f=2&t=73987
johnmx3ze
Post by johnmx3ze »
pm'ed you Dan the man with the big banane!
Flyer
Post by Flyer »
Dunlop Direzza Sport Z1 Star Spec
stereoking15
Post by stereoking15 »
I'm rolling on 235/40/17 toyo r888 pricey but stickey but i'm also running a 1/8 spacer on all 4 to clear. If you are looking for the best grip thats the best way to go. If money is a concern then look at a 215/40/17 no need for spacers look at the kumho ecsta xs, dunlop z1 star spec, sumitomo htr z3, falken rt615 or fk452. NOTE; a 225 45 17 will not fit well it is too tall you must do some serious grind to the bottom of the front spring perches to make them fit and roll your fenders as I bought some tires at a track event that were that size but did end up working with some serious mods.
