stroker kit
Posted: March 8th, 2011, 7:44 pm
by mazdaman222
is there a stroker kit being produced for the 1.6l 4cyl by any company if so where can i find it any info will be appreciated thanks
Re: stroker kit
Posted: March 8th, 2011, 7:54 pm
by pox
Re: stroker kit
Posted: March 8th, 2011, 7:57 pm
by Josh
Not to my knowledge, only one i know of is for the BP 2.0L stroker. I think there are two companies’s making them. The 1.6 is bored out pretty much to its max the little guy started its life at a 1.3L
Re: stroker kit
Posted: March 8th, 2011, 7:59 pm
by mazdaman222
ok do u know if the stroke from a bp would fit in the 1.6 or would there not be enough room?
Re: stroker kit
Posted: March 8th, 2011, 10:46 pm
by RS_OBD'oh_2
WHY? For that price you could turbo the damn car and get 100X more power than a stroker kit.
Re: stroker kit
Posted: March 8th, 2011, 11:58 pm
by Ryan
The engines are totally different... a BP is a different block than a B6. Different everything.
stroker kits are for v8's...
Re: stroker kit
Posted: March 9th, 2011, 3:41 pm
by mazdaman222
i mean if i get the stock piston arms and crank and keep the 1.6 pistons that wont fit in the 1.6 the 1.6 has a stroke of 83.6mm and the bp has a stroke of 85mm all i was wondering is if it would fit
Re: stroker kit
Posted: March 9th, 2011, 4:07 pm
by Ryan
I just said. Different blocks.
No.
Crank is a different length, cylinder spacing is different, journals probably aren't the same size.
Re: stroker kit
Posted: March 9th, 2011, 4:08 pm
by Savin
BP crank won't fit in a B6. The stroker B6 idea is dumb. If it could work, it'd probably be no better than a stock BP anyway.
-Meh, Ryan, you beat me.
Ryan, stroker kits are for V6's too!
Like the 4.3L 350hp V6 stroker for tbirds and mustangs. *drools*
Re: stroker kit
Posted: March 9th, 2011, 4:16 pm
by Ryan
the gains from a stroker kit are directly proportional to how many cylinders you have
I want a stroker kit for my rotary...
Re: stroker kit
Posted: March 9th, 2011, 7:41 pm
by Nd4SpdSe
Ryan wrote:the gains from a stroker kit are directly proportional to how many cylinders you have
Me wants!
Re: stroker kit
Posted: March 16th, 2011, 1:44 pm
by Volones
@ mazdaman222
Look for a stroker kit for the 1st gen miata with the 1.6L
They were more popular a few years ago, but the older miatas either have them, or have been junked, so no demand = no supply.
Good Luck
Re: stroker kit
Posted: March 18th, 2011, 11:29 am
by Josh
I just found a 4.6L stroker kit for the B6 on a Miata forum...
Re: stroker kit
Posted: March 18th, 2011, 7:44 pm
by Ryan
Um, bulls---? The sleeve isn't even long enough to accommodate that.
Re: stroker kit
Posted: March 18th, 2011, 8:43 pm
by Savin
Unless, by "stroker kit" you mean, "take old crappy B6 out and drop in Ford 4.6L modular motor" Even then, I hope its at least a cobra motor.
