stroker kit
stroker kit
is there a stroker kit being produced for the 1.6l 4cyl by any company if so where can i find it any info will be appreciated thanks
Re: stroker kit
Took the bp+t out of the mx and swapped it into a 95 escort wagon.
- Josh
Re: stroker kit
Not to my knowledge, only one i know of is for the BP 2.0L stroker. I think there are two companies’s making them. The 1.6 is bored out pretty much to its max the little guy started its life at a 1.3L
Re: stroker kit
ok do u know if the stroke from a bp would fit in the 1.6 or would there not be enough room?
- RS_OBD'oh_2
Re: stroker kit
WHY? For that price you could turbo the damn car and get 100X more power than a stroker kit.
- Ryan
Re: stroker kit
The engines are totally different... a BP is a different block than a B6. Different everything.
stroker kits are for v8's...
Re: stroker kit
i mean if i get the stock piston arms and crank and keep the 1.6 pistons that wont fit in the 1.6 the 1.6 has a stroke of 83.6mm and the bp has a stroke of 85mm all i was wondering is if it would fit
- Ryan
Re: stroker kit
I just said. Different blocks.
No.
Crank is a different length, cylinder spacing is different, journals probably aren't the same size.
No.
- Savin
Re: stroker kit
BP crank won't fit in a B6. The stroker B6 idea is dumb. If it could work, it'd probably be no better than a stock BP anyway.
-Meh, Ryan, you beat me.
Ryan, stroker kits are for V6's too! Like the 4.3L 350hp V6 stroker for tbirds and mustangs. *drools*
'93 MX-3 GS - SOLD!
'93 MX-3 GS SE - Parts car!
'94 MX-3 GS - Scrapped
'94 MX-3 RS - Scrapped
'96 Sunfire SE - Scrapped
'03 Sunfire SE - Deathtrap
'95 Cavalier Base - Scrapped
'89 Mustang GT - SOLD!
'93 MX-3 GS - SOLD!
- Ryan
Re: stroker kit
the gains from a stroker kit are directly proportional to how many cylinders you have
I want a stroker kit for my rotary...
Re: stroker kit
Me wants!Ryan wrote:the gains from a stroker kit are directly proportional to how many cylinders you have
Re: stroker kit
@ mazdaman222
Look for a stroker kit for the 1st gen miata with the 1.6L
They were more popular a few years ago, but the older miatas either have them, or have been junked, so no demand = no supply.
Good Luck
Good Luck
Current Hypermiler, future EcoModder.
- Josh
Re: stroker kit
I just found a 4.6L stroker kit for the B6 on a Miata forum...
- Ryan
Re: stroker kit
Um, bulls---? The sleeve isn't even long enough to accommodate that.
- Savin
Re: stroker kit
Unless, by "stroker kit" you mean, "take old crappy B6 out and drop in Ford 4.6L modular motor" Even then, I hope its at least a cobra motor.
'93 MX-3 GS - SOLD!
'93 MX-3 GS - SOLD!
