My son-in-law was trying to adjust his idle. He now gets a faint hum. Heard when the engine is not on. It seems to be coming from the throttle position sensor area. Will changing its adjustment cause an electrical hum? Is that what he messed with? will following the two part post with pictures on this topic line fix his problem?
Thanks
engine hum, electrical
Re: engine hum, electrical
Can you link us to that two part post?dougbee wrote: will following the two part post with pictures on this topic line fix his problem?
Thanks
It is the one right at the top of this same section about cleaning and adjusting the throttle body (TB).
DougB
DougB
