anyone with an OBDII mx-3 ever done a KLG4 swap, wanted to do it, and have any good info on why it is not a common swap??
You fin the motor in a 1996 - 2002 mazda 626 i beleive. It is distributorless. Has the lightest crankshaft (by 7lbs) in the k series motors. Crank is missing the centre counter balance. Has 170hp. I dont know if it is also a 7000rpm redline. You can put DE, ZE intake on it. Bolts in place of a DE or ZE apparently. I guess it comes down to sensors if swapping this motor in????
Is it better than a DE????
KLG4 swaps
- mikeetown
KLG4 swaps
mikeetown
93 Black GS - J-spec KLDE, CLEAN CAR
92 Red GS - J-spec K8ZE, stripped interior - Written off
2004 Infinity G35 Track Edition - 6 speed manual
viewtopic.php?f=17&t=79142
- MrMazda92
Re: KLG4 swaps
It's been done before.
1998-2002 626s only
The cranks vary in weight by year, the differences are reported between 4 and 7 pounds.
Solid lifters(No more tap tap)
Redline is determined by the ECU, but I believe it remained unchanged.
DE intake porting, and the IM is one of the greatest components of the engine. Port, polish, keep!
9.5:1 CR pistons as well.
1998-2002 626s only
- mikeetown
Re: KLG4 swaps
well i just found a thread on KLG4 swaps and I guess its just as easy as a KLDE swap. I like the solid lifters. Probably a more refined motor i assume
mikeetown
- PATDIESEL
Re: KLG4 swaps
I've not messed with a G4, but I hear they are pretty much the same (from a hook-up perspective) as a DE. I am not sure how the distyless system would work on a OBD2 ECU since I have not messed with that either. HPPwdn might be able to help, but I know he runs a MSnS on his car and thus the stock ECU is not controling the spark. I would check one of the probe or mx6 forums. They are still swapping regularly and the G4 is much more common there.
PS- it is the best motor for a turbo set-up.
