Door panel rivets
mazdafamiliamx3
Door panel rivets
Soo my passenger door panel comes right off when someone uses the handle to close it. Any suggestions on where I could get some replacements? Thanks
- umcamara
Re: Door panel rivets
You'll find them here under "Clips and Fasteners" in the "Hardware" section:
http://autobodyclips.com/
that, and it sounds like you are missing the big screw that keeps the handle on the door
mazdafamiliamx3
im missing both of those on each side, any clue to what size they are so i can get some. Thanksninjajim4 wrote:that, and it sounds like you are missing the big screw that keeps the handle on the door
- Ryan
They go into plastic... so just eyeball it and pick something with a low pitch and deep threads
