Need Guide on a K8-KLZE swap
- cWs306
hey does anyone got a guide on how to do the k8 to KLZE swap??? i cannot find one at all !!! please and thanks muchly appreciated
- Ryan
Re: Need Guide on a K8-KLZE swap
Thats because there isn't one.
Pull out K8. Plop in KL. everything lines up and bolts up. With a little intuition (or guessing if you have to) it will all bolt together and just work.
THEN you get to work out the kinks, like EGR codes, some vac, number of thermosensors, etc.
- solo_ryder
- cWs306
yah thats the main thing i need to find out. is what all needs to be carried over or swapped out for the ze to work. im new to this if you havent noticed lol. so anything helps. thanks everyone.
