[WTB] Bronzoil 3rdLink, Friction Gear(Cam Washer)
Looking for an Item you'd like to buy? Post here.
This section is NOT for selling.
MrMazda92
Post by MrMazda92 »
Hey guys, I know my chances of getting the Cam Washer's are pretty slim, but I'm in need of 4 if at all possible. I'll buy sets of 2, if that works out.
I'm also in need of the 3rd link Bronzoil Bushing kit from Corksport, I've got the other 2 sets and they're wonderful. Great feel, tightened it up nicely too. I'm just looking to lose the final 1/4" of slop finally!
The cam washers are ~$13 a piece at the dealership here, and that seems a bit steep for such a small piece of metal. Make me a reasonable offer for 2 or 4 of them, and I'll paypal you same day.
The 3rd link bushing is $30 on Corksport.com
I'm not picky whether I get a new or used one, so long as it's not excessively worn.
The first reasonable offer will have a paypal response same day.
matt91gt
Re: [WTB] Bronzoil 3rdLink, Friction Gear(Cam Washer)
Post by matt91gt »
there is a homemade version of the 3rd link bushings using some bronze bushings from mccarmaster and a bolt
MrMazda92
Post by MrMazda92 »
Hmm, not a bad idea at all. It doesn't wear like the other 2, so it should work well enough.
Thanks. ;)
matt91gt
Post by matt91gt »
idk if you had found the bushings of not, but i got the part number from mcmaster.com its 5448T5 and you need 6 of them total for the bushings, or just 2 for the 3rd link. this is the stock size of 10mm Shaft Dia, 13mm OD, 10mm Length and a 16mm flange diameter
MrMazda92
Post by MrMazda92 »
Thanks!
Return to “MX-3 Related Want to Buy Forum”
