1.6L dohc RS clutch questions
RedBPmx3
Post by RedBPmx3 »
hey guys, can anyone tell me what if any clutches are compatible with the DOHC RS precidia transmission? (1995, 11/94 production run on vin number)
Are there any 1.6L dohc miata clutches that swap over at all?
Limegreen mx-3
Re: 1.6L dohc RS clutch questions
Post by Limegreen mx-3 »
Miata 1.6L fidanza flywheel
MX-3 94+ 1.6 dohc clutch disc (the clutch disc form a 92-93 1.6 sohc are smaller than that of the 1.6 dohc)
Miata 1.6L pressure plate (which ever brand you want.)
The miata flywheel will bolt up to the crank. You have to use the mx-3 dohc clutch disc because its a 20 spline count where the miata clutch disc is a 22 spline count. a bit of a Frankenstein setup.
