Looking for a good underhood ignition on power source
wohpony
Post by wohpony »
Hi guys,
Im trying to wire my fans on a seprate relay and im looking for the best easy to get to/splice ignition on power source under the hood. Any and all help will be greatly appreciated.
1993 Mazda MX-3 GS KLZE
Ryan
Re: Looking for a good underhood ignition on power source
Post by Ryan »
I don't know what you mean by ignition, but you could use their normal switched power source and just run your trigger wire all by yourself. use the wiring diagrams found in the 1995 online manual.
wohpony wrote:Hi guys,
You know, I did an override on my rad fans, that I think I ended up doing it tapping into the fuse box in the engine bay for either ABS or A/C, cause my car didn't have either. Just had to add a fuse and get the right spade connector that connects to the pin underneath.
wohpony
Post by wohpony »
Thanks for all the help. I ended up just spliceing into the power wire for the radio.
If you're powering the relay, that's fine, but if you're actually providing power to the fans, that won't nearly be adequate!
wohpony
Post by wohpony »
Yep just the relay. Have the fans connected to the battery.
