Protege strut compatibility?
RedBPmx3
Post by RedBPmx3 »
Hey all, anyone know wether or not 95-98
Mazda protege struts/springs bolt onto
An mx3??
pox
Re: Protege strut compatibility?
Post by pox »
They dont. BH proteges have three upper bolts as opposed to the MX-3s four. (EC chassis)
90-94 Protege (BG) will fit.
91-96 Escort (BG) will fit.
90-94 323 (BG) will fit.
91-95 Tracer (BG) will fit.
Took the bp+t out of the mx and swapped it into a 95 escort wagon. ;)
RedBPmx3
Post by RedBPmx3 »
I'll correct myself an rephrase
Struts springs notincluding top mounts
pox
Post by pox »
Just the coil spring?
If thats the case, it should work (as per rockauto.com part number interchangeability). But I dont think any one has tried using a BH spring on a BG/EC car. Or vice versa.
Which springs are you looking at?
Ryan
Post by Ryan »
I would vote no unless pre 1994 protege. There are lots of things to consider. The angle at which it meets the spindle, the length, the width of the spindle, the ride height, the spring diameter, and if you're talking inserts, the strut diameter.
1994 and up protege is the BH chassis, and we are not compatible with that chassis.
Post by wytbishop »
The important thing to note is, that although rockauto lists a compatible part number, from the factory most of these cars have different spring and damping rates. Going to an aftermarket universal spring or using the factory spring from another BG chassis will affect handling. Not the end of the world, but something to think about.
pox
Post by pox »
Ryan wrote:I would vote no unless pre 1994 protege. There are lots of things to consider. The angle at which it meets the spindle, the length, the width of the spindle, the ride height, the spring diameter, and if you're talking inserts, the strut diameter.
94 is BG, 95-98 is BH.
RedBPmx3
Post by RedBPmx3 »
Mods feel free to close thread
Answer and Info received!
Thanks
