Hey looking for a front K8/KL exhaust manifold, with either good studs or usuable threads if the studs are pulled...i need the "short" manifold, only a few inches tell.
Also need a clutch slave cylinder, I believe all K8/KL are the same, all the way into the KLG4 engine.
located north of Barrie, so i can meet around there, or if you can ship that'll work too, thanks.
Jack
[WTB] V6 front exh manifold & clutch slave cyl
.::Mazda::speeD::.
working on the 2nd part
- mikeetown
Re: [WTB] V6 front exh manifold & clutch slave cyl
You should buy a new clutch slave cylinder. Its not worth installing an old one. Just a Pain to do it again. Just my advice. See if it is cheaper to get headers made before u buy a square block of steal mx-3 exhaust manifold lol.Mazda_Powered wrote:Hey looking for a front K8/KL exhaust manifold, with either good studs or usuable threads if the studs are pulled...i need the "short" manifold, only a few inches tell.
Jack
mikeetown
93 Black GS - J-spec KLDE, CLEAN CAR
92 Red GS - J-spec K8ZE, stripped interior - Written off
2004 Infinity G35 Track Edition - 6 speed manual
viewtopic.php?f=17&t=79142
I forgot you still needed that manifold Jack. I still have mine from the mx3. You know how to reachme best
1993 Mazda Protege LX soon to be bp-t3 powered
