a few............ issues with my 92 1.8L v6 auto
- newdriver92
1. brownish green foam sludge in filler cap?
2. shudders but doesn't stall. happens once in a while at light intersections, turning, accelerating (sudden) and coming down mountian highways?
3. as u stand i front of the car, facing the engine there is a tic tic tic tic tic tic tic tic tic sound on the left side?
Forgot
4.Backfires with hard accelerating, or sudden acceleration after intersection linked with number 2 I think
i replaced: battery, spark plug leads, pick up (its on the distributor), mass airflow sensor, coolant flush.
its not over heating.
i think the idle may be a bit high
thanks if anyone can help
Forgot
Last edited by newdriver92 on November 19th, 2010, 2:05 am, edited 1 time in total.
worklog viewtopic.php?f=46&t=77147
other pics of the adventures me and the car have been on http://s1082.photobucket.com/home/newdriver92/index
- Ryan
Re: a few............ issues with my 92 1.8L v6 auto
Motor is likely screwed.
Your coolant is leaking into your oil. this is a head gasket, or cracked/warped head or block.
The tic tic tic is the friction gear spring. $20 and 4-6 hours of labor to fix that.
The shudder/stall is likely a vacuum issue. Not fatal or hard to fix.
Personally, I'd suggest a KLDE/KLZE swap instead of trying to fix the coolant problem. I hate coolant problems.
- newdriver92
great
- Ryan
All hope is not lost...
Did you make an intro post? how are your mechanical skills? any access to tools? got lots of money?
All of those things help, but you're not screwed if you don't have any of them... cars honestly aren't too complicated, you can learn if you want to. This forum can provide bolt by bolt instructions if you need, but we pray you don't.
First and foremost, change your poor oil and see what condition your coolant overflow reservoir is in.
- newdriver92
i would say first year mech maybe but my pops is a mech
i got access to some tools
money i think i got that coverd i hope
i will get an oil change
- newdriver92
i haven't seen any traces of coolant in oil
i did a home coolant flush so i think maybe i did a bad job cause i totally forgot to bring it up to running temp before adding new coolant and for got to clean overflow tank
- MrMazda92
All good answers, except the last one! You should change your own oil any time you are able! Honestly, it's something many people(even some mechanics) don't like to do themselves. For the simplicity of it, and the savings(both short and longterm!) it is a big bang for your buck job. If you meant you will change it, my mistake! If not, free advice Either way, welcome!newdriver92 wrote:i would say first year mech maybe but my pops is a mech
- newdriver92
I thank u for the advice I just hope it nothing too serious
- newdriver92
Ill keep u posted
- newdriver92
any one in the edmonton area wanting to help me at pick and pull i want to find parts for my mx-3
- newdriver92
Off I go to the pick and pull any one wana join
- MrMazda92
I would in a heartbeat if I was in the area, my local JYs are MX-3 lacking... Mazda lacking period, there are under 50 Mazdas in the entire yard by my house, which is the largest pick n pull.
- newdriver92
Yaa same there's only 4 mx-3's there but one has racing kit in it soo that's wut I'm going to pull apart tomorrow
- newdriver92
What a great time to find out your block heater doesn't work
- newdriver92
I am wondering around howmuch a engine swap would cost me
