MX-6 OBX Header?
- bbunkerc397
MX-6 OBX Header?
How much work would it be to mod up a OBX MX-6 headers to fit in our mx's. Any comments?
1996 MX-3 KL-ZE with Eunos 800 IM, factory side skirts,. "Owner since 2001 my 14th year"
1992 929s 20B-REW Lowered, 17" chrome Millenia rims, custom black interior. "13th Owner 9th year"
2006 Chevy HHR LT "Bought Brand New - East Side Chevy" Sold to my Dad
Re: MX-6 OBX Header?
I put on the Probe ones for my ZE swap. No issue - BUT I also put a new custom exhaust on from the end of where the headers come together all the way back.....still "testing" my cat....you know....
1993 GS SE - "slow" (Stock) - SOLD
1993 GS SE - "fast" (Curved neck KLZE, OBX headers, custom 2.5" exhaust, KL36 ECU, Exedy Probe GT clutch, KL36 LSD - the real one, Lantis Type R lefthand halfshaft - unfortunately worth mentioning)- SOLD
1993 GS SE - acquired 4/28/2013, SOLD February 28, 2015
1985 RX-7 GSL-SE - SOLD
2003 VW GTI 1.8T
2009 Mazda5 Grand Touring
2003 VW GTI 1.8T
- bbunkerc397
Thanks, everything fit ok?
Mine were 1st gens, horrible fitament on my Mx-3, so depends which revision, so could be ok, or could be bad, but those 1st gens should be around anymore, that's been a long time
The only issue is that the MX-6 and Probe locate their cat farther to the rear of the car then ours - so you might have an issue if you are reusing your cat.
2003 VW GTI 1.8T
2003 VW GTI 1.8T
- bbunkerc397
so then do a custom cat back as well then?
thats never a bad idea
For pretty much all of them yes, but mine, wouldn't clear the oil pan and the one o2 sensor bung was actually facing the block, so you couldn't get an 02 sensor in there never mind with it's connector.ganue wrote:The only issue is that the MX-6 and Probe locate their cat farther to the rear of the car then ours - so you might have an issue if you are reusing your cat.
- bbunkerc397
Well by the sounds of things it seems to be a little work but nothing I can't handle.
