Engine Wont Start: Note to Others about Fuel Inj. System
h3xt0r
Post by h3xt0r »
Yes, another engine wont start thread! Yay! However, it isn't your normal wont start thread... I've already found the cause of the engine failure. I simply want to point out to others why it failed & how I figured it out so that in the future they don't fall prey to the same error. First off, I want to thank Ryan for helping me out and leading me in the right direction.
As everyone else that I know kept telling me, "It's something stupid". I went the entire fuel injection system replacing wires, checking systems, the whole 9 yards. I checked everything! So like Ryan suggested I sat down by the car, with a beer, and the WHOLE 160 page Fuel and Emission Control Systems. Sitting there, drinking my beer, I got to page 110.
Than it hit me...Did I really? I hooked the fuel lines up backwards. Switched them back and low and behold ZOOM ZOOM! Why does it not work the other way around? The fuel rails work in funny ways...(Not really...) You have the fuel pump at the tank that sends it up to the fuel filter (xD Thanks Inodoro) in the engine bay that pressurizes the fuel rails. The fuel comes in on one side than loops over to the other and whats left over gets sent back to the fuel tank. This is a one way system. So if you hook it up backwards no fuel will make it to the injectors and so on.
So the moral of the story?: Get a beer, the manual and read away!
-H3xT0r
kateCapshaw wrote:The moment somebody says to me, "This is very risky," is the moment it becomes attractive to me.
K_I_R_K_S
Re: Engine Wont Start: Note to Others about Fuel Inj. System
Post by K_I_R_K_S »
hahahhahahahahahahaha iv done that before... only took 5 min to work out...
the fuel regulator is a one way valve that only opens at a certain pressure..
Orange 1995 Eunos 30X Race car KLDE
Orange 1994 Ford Telstar Race car KLDE-sold
Mazda 323 BF Turbo racecar in the build
Blue Mazda MX6 V6 4ws
Ford Telstar TX5 v6 4ws
Inodoro Pereyra
Post by Inodoro Pereyra »
h3xt0r wrote:The fuel rails work in funny ways...(Not really...) You have the fuel pump at the tank that sends it up to the fuel pump in the engine bay that pressurizes the fuel rails.
Fuel pump in the engine bay? :confused2:
Sorry H3xtor, but I think you're seeing things.
The fuel line comes from the fuel pump in the tank, to the fuel filter, to the rails, then the FPR, then back to the tank.
That's, unless you installed an inline fuel pump...
Diogenes of Sinope.
mikeinaus
Post by mikeinaus »
i did the exact same thing when i swapped my motor. you should have asked solo_ryder, he knew what the problem was instantly lol.
ganue
Post by ganue »
Guilty here too.....
1993 GS SE - "slow" (Stock) - SOLD
1993 GS SE - "fast" (Curved neck KLZE, OBX headers, custom 2.5" exhaust, KL36 ECU, Exedy Probe GT clutch, KL36 LSD - the real one, Lantis Type R lefthand halfshaft - unfortunately worth mentioning)- SOLD
1993 GS SE - acquired 4/28/2013, SOLD February 28, 2015
1985 RX-7 GSL-SE - SOLD
2003 VW GTI 1.8T
2009 Mazda5 Grand Touring
Inodoro Pereyra
A little tip to avoid that problem: the pressure hose (the one that comes from the pump) goes to a banjo fitting at the end of the fuel rail. Instead of removing the hose clamps, remove the bolt in the banjo fitting (be careful not to lose the copper washers). That way, when you have to reassemble everything, you know the hose with the banjo is the pressure hose. :welder:
Diogenes of Sinope.
Ryan
Post by Ryan »
Or just remember that the fuel filter goes straight to the lines, and the FPR is the last piece before it returns to tank...
So, know how the fuel system works.
_-Night-Shade-_
Post by _-Night-Shade-_ »
I just keep a mental note that the hose coming from the fuel filter connects to the one closer to the firewall.
h3xt0r
Post by h3xt0r »
You're right Inodoro, it's the fuel filter and not a fuel pump. :-P
-H3xT0r
