something interesting on K-series
- mikeetown
found this on probe talk.
August 16th, 2006, 12:00 AM #7
mx6gt04
Turbo Member
The K8 bore is 85mm vs. 84.5mm of the KL (yes, awkward as it sounds the smaller engine has a bigger bore). The difference is the stroke.
The 1.8 and 2.0 V6 rods are itty bitty, worse than the 2.5. Ive compared them side by side. It would self destruct much easier, and that's pretty sad seeing how easy the KL rods bend and break....
__________________
94 MX3 V6 - 403 whp 412 ft lbs @ 15 psi pump gas. RIP
98 Ford Ranger 2wd: 5.0L twin turbo. 6 psi
04 GSXR 600 - -1/+5, stand up wheelie machine. 01 YZ250
95 PGT: 87k... 18" wheels, tokico struts and springs... SLOW
so, i always thought the K8's would be stronger than KL's at high revs (5000 - 7500 rpm).
mx6gt04
Turbo Member
__________________
mikeetown
93 Black GS - J-spec KLDE, CLEAN CAR
92 Red GS - J-spec K8ZE, stripped interior - Written off
2004 Infinity G35 Track Edition - 6 speed manual
viewtopic.php?f=17&t=79142
- _-Night-Shade-_
Re: something interesting on K-series
No. Comparing apples and oranges.
- Inodoro Pereyra
Mike: that information is wrong. The K8 has a bore of 75 mm, not 85, and a stroke of 69.6mm.
The KF (2.0L) has a bore of 78mm, and the same stroke as the K8.
The KL has a bore of 84.5mm, and a stroke of 74.2mm.
Diogenes of Sinope.
Diogenes of Sinope.
Yep Inodoro is right, my sources also indicate it's 75mm x 69.6mm for K8
84.5mm x 74.2mm For the KL
Also when rebuilding my engine and having a spare K8 short block next to it, the pistons on the K8 look very tiny.
1995 Eunos 30x KLZE
- Ryan
When comparing my ZE and K8 pistons side by side, I would also have to definately agree K8 are 75 and KL are 84.5
- PATDIESEL
I wonder if it is a mistake and they were looking at or measuring 4 banger parts... odd to be so confident and so off at the same time...
- Ryan
PATDIESEL wrote:... odd to be so confident and so off at the same time...
That's not odd at all, I think that's how countless misconceptions happen on forums... someone sounds like they know what they're talking about when the have no clue.
- Inodoro Pereyra
I have to say that, more than odd, I find it...sad...PATDIESEL wrote:I wonder if it is a mistake and they were looking at or measuring 4 banger parts... odd to be so confident and so off at the same time...
There's no need to measure anything to get the right numbers. I didn't measure anything.
Just a 10 second google, and I found what I was looking for here:
http://en.wikipedia.org/wiki/Mazda_K_engine
...and here:
http://www.tsentraal.ee/mx6/engine/SAE920677.htm
...and I'm pretty sure that, had I not been satisfied, I could have found many more sources for the same data.
I agree with Ryan. That looks a lot more like the work of somebody who didn't have a clue what he was talking about, and didn't care to check his information before posting it, than somebody making just an honest mistake.
Diogenes of Sinope.
Diogenes of Sinope.
- mikeetown
Well, i came across that and just had to post it for you Gou guys. good thing i did.
mikeetown
