I need the wiring diagram section from the Mazda service manual for a 1993 MX3 SOHC 1.6L
If you can help me out or know were to get it?
Thanks Rusty
Need a 1993 MX3 Mazda service manual wiring diagrams
- Meghan
Re: Need a 1993 MX3 Mazda service manual wiring diagrams
Chilton's has almost everything you need to know about the car. There are a ton of wiring diagrams in it. Check your local auto parts store. It's about $20.
It's Meghan
No matter how bad things seem, they can't get any better and they can't get any worse cause that's the way things f---ing are. So you better get used to it Nancy. Quit your b----ing.
- umcamara
What wiring schematic do you need in particular? The '95 schematics in the online manual, although perhaps different, may be somewhat of a reference point.rusty wrote:I need the wiring diagram section from the Mazda service manual for a 1993 MX3 SOHC 1.6L
Thanks Rusty
I know this is a little late, but I have detailed wiring diagrams for the 93 in pdf form. I think they're different than the online stuff, I'm not gonna check at the moment. I can send them to you if you still need them.
93 MX-3 BP - Worklog
Anyone ever check link to manuals on the main site? mx-3.com, lower left column is a tab for full service manuals...
There's a 95 manual online but its a little different then 93. And i need the mazda manual info as my chilton book isn't detailed enough
