They are NOT TTY. Not in the conventional sense at least.
Sheesh.
Need I find several references?
http://www.mx-3.com/manuals/showimg.php ... B2-101.gif" onclick="window.open(this.href);return false;
There is the manual giving you a spec to measure against, as well as the turn-to-torque procedure.
http://www.enginebuildermag.com/Article ... angle.aspx" onclick="window.open(this.href);return false;
There is an excellent article everyone should read.
If the bolts are in spec, just re-use them. People on here, and on PT have been re-using headbolts for a very long time. I haven't even ever heard of a single case of headbolt failure. I can't speak for premature HG failure. Plus you could never accurately blame this exact issue. Improper torque-ing is MUCH more likely.
If you read that article, you'd see that all bolts stretch, and every time you torque them(enough), they stretch some more. Thats the reason for this spec given by Mazda. Once the bolts have stretched beyond that point, THEN they are no longer safe to use. Instead of telling us to "use them 6 times" (which would be stupid, who could ever keep accurate track of that) they give you a measurement that will reflect the number of times it has been torqued, and of course, the root idea, the safe stretch limit of the bolts.
If you have an extra $150 to throw at headbolts, then sure, do that, but I sure don't, and wouldn't.
The spec in the manual is given for a REASON. If Mazda wanted you to replace the bolts, they'd tell you to use NEW ones, and REPLACE, and make it all bold and obvious like they do for all parts they do want you to replace...
If you're building a high performance motor thats going to be putting down much more power via higher compression/boost/NO2, then I would suggest ARP head studs, as they are far superior in the fact that they are not twisted on installation, and therefore torquing them does not put on as much stress as friction is much much less. Just open your pockets.
Edit, here's a neat BITOG article. Thats a neat site...
http://www.bobistheoilguy.com/forums/ub ... 932&page=1" onclick="window.open(this.href);return false;
Black GS - Summer DD/Race car -
Fancy KLZE
