AaronTietje - 1993 MX3 Phase 2
AaronTietje
Post by AaronTietje »
Well Its about time I make a worklog :D
The project (starting spring of 2010):
1993 RASPBERRY very clean (picked up in NJ)
I immediately put the car under the knife
The engine bay has been stripped down and painted. (BLACK)
INSTALLED: 2.5 95 PGT engine
Fidanza
Stage 3 clutch
Modified tensioner due to the power-steering delete.
Manual 323 rack
G4 intake
94 dash :welder: :welder: :welder: :welder: Pain in the BUTT
Stainless headers
DELETED: Power-steering (including lines, pump, etc.)
AC (including lines,pump, condenser, etc.)
Heater-core
All vents (gauges will be installed)
Cruse
AD fan, and ABS relays/wiring
Large amount of vacuum lined due to the G4 intake and front valve
cover
EGR
Charcoal canister
Moonroof assembly
Auto seat belts
Parts sitting around to install.
JDM side skirts
Slim fans
Exhaust Pasesetter
Big brake kit using wilwood, afco, and tenzo R parts
Sparco corsa buckets
N2o kit
Warbro
Milly injectors
Colt cams NA 210 grind
Lsd Trans
SRD front control arm bushings
ELM joint swaybar links
Corksport shifter bushings and 3rd link
Corksport clutch line
Hid kit
Clear/chrome headlights
Factory fuel pressure regulator delete hose and aftermarket pressure regulator
Sleeper6
Re: AaronTietje - 1993 MX-3 GS
Post by Sleeper6 »
Nice to see you finally got a log up, now all you need is the pics so everyone can see the work you've put in. (Ive made a few trips to his house to swap parts :mrgreen: ) Not to mention that engine definatly makes me a lil' jealous sitting all pretty in there!
AaronTietje
AaronTietje
Finally some pics. :D
That is my buddy Mike working his magic on the new KL.
Also, you can see the new manual rack :mrgreen:
solo_ryder
Post by solo_ryder »
Lookin good! I like the valvecover. KLG4 IM?
AaronTietje
Sure is. It is the first G4 that I have had, so I don't have an official opinion of it other than it looks good. :lol:
AaronTietje
If you look close you can see that I got around the "lip problem" on the G4 intake with a spacer. I then used
a Mx3 TB. :welder:
AaronTietje
Finely got myself a set of mint fronts. :D :D :D
I got in contact with a guy on CL about a parts car......long story short he gave me the leather portions I needed to make mine perfect.
AaronTietje
I did some cleaning in the garage today and made it easy to work on the MX3.
My dash will not have any of the vents left when I am done. I am also putting in a push start in the 94 flasher position and have mounted in the old style flasher so that I still have one.
Inodoro Pereyra
Post by Inodoro Pereyra »
Hmmm...no A/C and leather seats? You're about to lose some weight... :lol: :lol:
Anyway, looking good so far. Love the valve covers. Are you gonna paint the letters?
Diogenes of Sinope.
AaronTietje
Inodoro Pereyra wrote:Hmmm...no A/C and leather seats? You're about to lose some weight... :lol: :lol:
Yah, its going to be hot.... lol...... The lettering will be polished when I finally get a chance. The body of the car will also be a burnt orange that matches the VC's.
AaronTietje
I just got a package from Japan Post :D :D :D :D :D :D
Pics up soon.
solo_ryder
Pics NAO!
Also, 94 dash in a 93 SE ftw. I like what you did with the start button there and using the 93 hazard switch, good idea for sure
AaronTietje
HERES THE PICS
I do have the complete set including the fender caps.
Holy crap!!!! I could not believe how little these things way. I had a euro mini in one hand and my JDM skirt in the other and it was almost identical in weight. :lol:
sorry about the poor pics. I will bet better ones once the car is mobile.
AaronTietje
solo_ryder wrote:Pics NAO!
I used my 93 dash harness so the 94 hazard was of no use to me unless I rewired. I don't think I will ever attempt another one of these dash swaps. It was a huge pain and just not fun.........but im glad I have it now lol.
