Changing pistons with engine in ?
lerutis
Post by lerutis »
Hi !
I'm about to buy KLZE cams and pistons for my Millenia KLZE wannabe but i just need some more info on if i can do the piston change without pulling the engine out ?
Re: Changing pistons with engine in ?
It'll depend on the condition of the cylinder walls. If there's wear ridges you'll need to have the block machined but at the very least you need to make sure you hone the cylinder walls or your new rings will never wear in. For the extra couple of hours it would take to pull the engine it'll save you a lot of climbing in and out from under the engine. IMO
RX8SE3P
Post by RX8SE3P »
definitely pull the engine, waaaaay easier.
1995 Eunos 30x KLZE
