supercharger
- wreckedgs
supercharger
Ok probably been covered already but will the SC from the millenia 2.3 fit on a k8?
- WhiteFinish
Re: supercharger
use the search button then when you know it has been told many times.
But yes, you can use the ss from the miller, only generates very low psi of boost so not worth your while.
Re: supercharger
No you can't. the heads on the KJ are different to allow the Supercharger to fit in between.
Technically you can put in any supercharger from any vehicle to any motor, you just have to make your own custom mounts and piping, but the KJ S/C isn't designed to mount like a standard supercharger and probably would be the hardest ones to make work
- PATDIESEL
Re: supercharger
The KJ is a 90* V6 and the KL and K8 are 60* motors.
Re: supercharger
Actually it's not...we've been corrected on that and it's a 60 degree motor, but the cam pulley on the rear bank is inline the exhaust cam and not the intake, so it looks like it's a 90 degree
