Some vacuum questions, pictures inside.
lerutis
Post by lerutis »
Hey hey
So i'm almost done and we have a few vaccum hoses that we have no clue where to put em. We've checked the wiring diagrams but we are not sure.
Pictures:
From the throttlebody
Any idea?
No idea what this does, i have no cable for it :o , seems like a vacuum vent or something.
More picture of this vacuum vent.
All help is apprecicated.
Engine is KLZE from Millenia -95.
_-Night-Shade-_
Re: Some vacuum questions, pictures inside.
Post by _-Night-Shade-_ »
Buddy, what a mess. Couldn't even tell you where that hose goes cause it's too messy in the pics, could be anything. The plug is actually the Purge Solenoid Valve, on MX-3s it is bolted to the firewall but on Millenias it is bolted to the IM, so you can just take it off as it's useless.
Hopefully this helps:
lerutis
Post by lerutis »
Ah i see :( , yes its hard to take good pictures.
So i can just let it be or do i need to remove the purge solenoid from the engine?
Thanks!
PATDIESEL
Post by PATDIESEL »
True ZEs do not use EGR, so you would just take the silinoid off. However, if you are using a KL-DE from a Millinea then you probably still have EGR and need to connect it per the diagram.
I have seen some people call a Millinea 2.5L a ZE because they use the ZE cams. However, it is still a DE b/c it uses the lower compression pistons and DE heads.
