ok you've prolly seen this question before but i havent found what im looking for.
now i have a 94 mx3 gs 1.8l that im about to swap out for the KLZE 2.5l and i dont want to waste the 1.8l because its still got life in it just need to replace some gaskets and some basic tuning which i can do after the swap.
i found a good body for the 1.8l but it comes with the 4cyl engine,will the 1.8l bolt properly into the engine bay of the base 4cyl modle?
i know ima have to swap the tranny and wiring harness is there anything else that im going to need to change?
any foreseeable problems that might occure?
thanks for the help ^_^
will a 1.8l bolt properly into a 4cyl engine bay?
- kira_kira
what you think id let u roll in a hyundai?
- RS_OBD'oh_2
Re: will a 1.8l bolt properly into a 4cyl engine bay?
gah
http://www.mx-3.com/phpBB3/search.php" onclick="window.open(this.href);return false;
Dont forget the motor mounts and the flux capacitor.
Took the bp+t out of the mx and swapped it into a 95 escort wagon.
- RS_OBD'oh_2
and you'll need new johnson rods
- kira_kira
not sure i can get a flux capicitor seeing as how i havent seen a de lorean in quite some years that i can rip one out of >_>
lol, just a couple clicks away...
viewtopic.php?f=3&t=74200" onclick="window.open(this.href);return false;
viewtopic.php?f=15&t=73581" onclick="window.open(this.href);return false;
viewtopic.php?f=3&t=72150" onclick="window.open(this.href);return false;
