Clutch Pedal Assembly
kaynhew
Post by kaynhew »
I'm changing from autmatic to manual transmision.
The situation is that i removed only the clutch pedal from a mazda protege and i don't how to install the pedal back in my mx-3. I saw a exploded view of the pedal in the manual, but doesn't show where to put the spring. Someone told me that i have to take the whole part (don't know the name) that hold the brake pedal and the clutch, but i don't know how to do it. :?
I need some help on this:?:
Re: Clutch Pedal Assembly
User the 'Search' function, there's a big write up on doing the conversion. Step by step. Cheers
kaynhew
Post by kaynhew »
I'm search but i can't find it... What's the topic? :? :?: :?:
EggyRollz
Post by EggyRollz »
Well if you get down there and look the entire bracket for the automatics is one whole assembly. However , there is 2 options :
1 : remove the beast and get some manual pedal assemblies for who knows how much and install them and go that way.
2 : Use a grinder and get in there and grind the dud clutch bracket out and go find a 94+ where they have stand alone clutch pedal assemblies (such as the one in my for sales) and install it that way then you dont have to worry about the brake bracket. This should be fairly easy since the points of which I will grind are the weakest connections between the main brake bracket & clutch dud bracket.
P.S. - I am going #2.
94 Tahoe Sport SS - 454 =)
93 3KGT VR4 - K&N Filter.Proxes 4 Tires. Drilled/Slotted Rotors.
97 Tahoe - Grill gaurd.Oversized Tires.Custom liners.Bored & matched pistons.E-cam.Leather.Remote start.TCC upgrade.+Sunshell.10K tow package.Knifed TB.Flowtech Huggers.Straight pipes.Hypertech chip.B&M Trans Controller, Front diff & T-case plates.
Feedback-viewtopic.php?f=37&t=74259
For Sale-viewtopic.php?f=2&t=74832
mrwhite
Post by mrwhite »
Is that stand alone assembly still for sale
Return to “Transmissions”
