[wtb] 96 mx3 o2 sensors V6
need 2 o2 sensors for a v6 in working condition.
Re: [wtb] 96 mx3 o2 sensors V6
You're best off buying these new. Take a look at Rockauto.com, they have some good prices.
'94 MX3 GS (black)-- 2.5L DE w/ straight neck IM, SSAC Headers, KYB-GR2's, Intrax Springs, CM Stage I clutch, OBX STS, filled front & rear mounts, CAI- SOLD ![Sad :(](./images/smilies/icon_sad.gif)
Are they the plug and play or more universal style where i have to match colors and stuff
- Ryan
You can get either, but the price difference is like $60 to have the proper plug on it. I like soldering enough, I'm willing to save $120 to spend 20 minutes soldering. Wow, thats like, $360 an hour... to solder... not bad.
Plug and play is the way to go. Check out FAX (daninski) for the proper pn for your 96. Denso are the oem O2 sensors. I bought mine $115 for two delivered to Canada from Rockauto. O2 sensors are exposed to a lot of heat vibration and fluids so make sure if you buy universal (bad idea) your solder joints are perfect and double up on the heat shrink.
PS Ryans cheap so take what he says with a grain of salt.![Smile :)](./images/smilies/icon_smile.gif)
Would you be able to provide me with a link??
I can't believe I'm doing this, must be because it's Friday. Really you need to familiarize yourself with the available Forums here.
http://www.mx-3.com/phpBB3/viewtopic.php?f=23&t=65706" onclick="window.open(this.href);return false;
the bottom two are only ther to monitor the O2 sensors so don't worry about those. In fact you can disconnect them and nothing will happen.
Thanks alot. You are officially the man. This is much appreciated.
just purchased 2 of them. thanks once again daninski.
