different size rims
eydi
different size rims
Post by eydi »
has anybody here tried putting 16" up fronts and 17" on the back? the reason I am asking is i know this guy that has 2 sets of rims (exact same model) but different in sizes. He got into an accident twice and the some of the rims are messed up. Now he only has 3-16" and 2-17" and he is willing to let all of it go for $150. I am just wondering the pros and cons of this. If I ever do this, both the fronts and back would have the same tire size of course (in diameter). Thanks guys
Re: different size rims
Post by wytbishop »
You could get the overall diameter of the wheels close enough that it wouldn't cause any problems but it would just look ridiculous.
205/50/16 and 205/45/17 are about the same diameter as stock.
solo_ryder
Post by solo_ryder »
Its possible, but also stupid as hell. The only reason u should be doing that is if the car is designed for it (like the chrysler crossfire), if you are running gnarly wheel setup and you want some agressive tires on the back or if you are running some type of slick on the front of the car and u need a small and wide rim to get the sidewall needed.
As for a normal rim, that's possible but not cool. You would need to make sure the tire diameters for the front and rear are pretty much equal so that there is even wear and the car drives normal.
What I suggest is you buy the 16s and then source 1 rim whether it be new or used, so that you have a full set. That's the best option. Don't mix and match
eydi
Post by eydi »
ok guys thanks alot... I just havent seen any cars like that other than the Acura NSX ofcourse and it doesnt look bad on the NSX. its just a thought
Post by wytbishop »
There are a few cars that are given that look but their suspension is designed for the rear wheels to have a larger overall diameter than the front. If you did that your MX-3 would handle very badly.
Ryan
Post by Ryan »
Its just a bad idea. Unless you've got a crazy track set up with serious slicks on the front and skinnies on the back, its a bad idea.
